How to display higher-level (theme) data when no lower-level (indicator) data is selected in ArcGIS Dashboards
503
10-15-2025 08:17 AM
GOffenberg
I'm creating a dashboard that visualises data at municipality and neighbourhood level.
I have a sidebar where users can first select the scale level, then a theme, and finally an indicator (each indicator belongs to a theme).
Currently I have all data (municipality, neighborhood, theme and indicator) saved in one dataset (created using the ArcGIS Python API)
However, I also have data on the theme level only — representing an aggregated score of all indicators within that theme.
My issue: I can’t visualise the theme-level score when no indicator is selected.
When I enable the “None option” in the indicator selector, the map showing only the theme score does not appear.
How can I include and display the theme-level maps in the dashboard when no specific indicator is selected?
Thanks in advance for your help!
Kind regards,
Geert Offenberg
MiaWhite34
Use a separate layer for theme-level data and set your dashboard to display it when the indicator selector is “None.” Toggle visibility so the theme layer shows only when no specific indicator is chosen.
