Help with Data Expression to Sumarize Spatial Joined Features
726
12-19-2024 11:26 AM
Adam_blaine
I'm trying to write an Arcade data expression to calculate summary statistics for a line layer of pipes, grouped by a polygon layer of sewersheds, but I'm struggling. Goal output would be the following table:
SewershedLength of all pipe features
A10,000
B9,000
C11,000
Here's the code that I've got so far, but I'm struggling to figure out how to get the sum of all pipe lengths, per intersecting feature (sewershed).
// Get sewersheds.
var sdata = FeatureSetByPortalItem(Portal('portalURL'), 'sewershedLayerID', 13);
// Get pipes.
var pdata = FeatureSetByPortalItem(Portal('portalURL'), 'pipeLayerID', 11);
// List all sewersheds
var sheds = Distinct(sdata, "sewershed"); // List of sewersheds.
// This line successfully returns what I want by the pipe type, but there's no intersection happening here. Instead of pipe type, I want the intersecting sewershed as the groupby category, and that's why I'm attempting this data expression instead of just bringing the layer into the dashboard.
return GroupBy(pdata, ['type'], {name: 'Total Pipe Length', expression: 'Shape__Length', statistic: 'sum'});
// Iterate each pipe and get the sewershed, but this isn't working and seems really inefficient anyway given that I have many thousands of pipes.
for (pipe in pdata) {
    var y = First(Intersects($feature, sdata));
    if (y == null) return;
I'm hoping to extrapolate the solution here to additional datasets. For example, I'll need to create the number of properties served in each sewershed, and similar for other datasets.
Tags (1)
