Help with Data Expression for Table Widget in ArcGIS Dashboard
944
06-05-2025 01:00 AM
GeoGeek
I'm seeking assistance with creating data expression for a table widget in ArcGIS Dashboard. I've been experimenting but haven't been able to achieve the desired outcome.
Here is my sample data:
Sample data
Only two fields are involved.
Here is the desired result:
Desired outcome in table widget
I've tried using Arcade expressions, but I'm unsure how to structure it.
Any guidance, examples, or resources would be greatly appreciated.
KenBuja
MVP Esteemed Contributor
Here's one way to do that. I used a dummy dataset to test it out, so substitute your actual dataset.
var fs = FeatureSet(
    fields: [
      { alias: "Person", name: "Person", type: "esriFieldTypeString" },
      { alias: "Status", name: "Status", type: "esriFieldTypeString" }
    features: [
      { attributes: { Person: "Person 1", Status: "Investigated" } },
      { attributes: { Person: "Person 1", Status: "Pending" } },
      { attributes: { Person: "Person 2", Status: "Investigated" } },
      { attributes: { Person: "Person 2", Status: "Pending" } },
      { attributes: { Person: "Person 3", Status: "Investigated" } },
      { attributes: { Person: "Person 3", Status: "Pending" } }
var statuses = ["Investigated", "Pending"];
var people = GroupBy(fs, "Person", { name: "Total", expression: "1", statistic: "Count" });
var peopleandstats = GroupBy(fs, ["Person", "Status"], { name: "Total", expression: "1", statistic: "Count" });
var features = [];
for (var p of people) {
  var person = p.Person;
  var attr = {};
  attr["Person"] = person;
  for (var status of statuses) {
    var s = First(Filter(peopleandstats, "Person = @person AND Status = @status"));
    attr[status] = s.Total;
    if (status == "Investigated")
      attr["Percentage"] = Round(s.Total / p.Total * 100, 0);
  attr["Total"] = p.Total;
  Push(features, { attributes: attr });
var fields = [
  { name: "Person", type: "esriFieldTypeString" },
  { name: "Investigated", type: "esriFieldTypeInteger" },
  { name: "Pending", type: "esriFieldTypeInteger" },
  { name: "Total", type: "esriFieldTypeInteger" },
  { name: "Percentage", type: "esriFieldTypeInteger" }
return FeatureSet({ fields: fields, features: features });
which returns this table
GeoGeek
Hi @KenBuja. Thank you for responding to my question.
Unfortunately, when I applied the expression to my dataset, it didn't work as expected. I suspect I might be misapplying part of the data expression.
Update
I made some progress, but I am stuck with getting the percentage.
var portal = Portal('https://arcgis.com/');
var fs = FeatureSetByPortalItem(
    portal,
    '9b5e49e6c3454c9fb6c1e0de31252e98',
    0,
        'INVESTIGATED_BY',
        'Status'
    false
var investigated = "CASE WHEN Status = 'Investigated'   THEN 1 ELSE 0 END"
var pending =   "CASE WHEN Status = 'Pending'           THEN 1 ELSE 0 END"
return Groupby(
    fs,
    ['INVESTIGATED_BY'],
        {name:'Total', expression: 'Status', statistic: 'COUNT'},
        {name:'Investigated', expression: investigated, statistic: 'SUM'},
        {name:'Pending', expression: pending, statistic: 'SUM'}
KenBuja
Good use of the Case statement in the GroupBy function. I always overlook that as a possible solution.
I believe you'll still have to loop through the grouped Featureset to calculate the percentage.
var investigated = "CASE WHEN Status = 'Investigated'   THEN 1 ELSE 0 END";
var pending = "CASE WHEN Status = 'Pending'           THEN 1 ELSE 0 END";
var grouped = Groupby(
  fs,
  ["Person"],
    { name: "Total", expression: "Status", statistic: "COUNT" },
    { name: "Investigated", expression: investigated, statistic: "SUM" },
    { name: "Pending", expression: pending, statistic: "SUM" }
var fields = Schema(grouped).fields;
Push(fields, { name: "Percentage", type: "esriFieldTypeDouble" });
var features = [];
for (var g in grouped) {
  push(
    features,
      attributes:
          Total: g.Total,
          Investigated: g.Investigated,
          Pending: g.Pending,
          Percentage: Round(g.Investigated / g.Total * 100)
