Help with Arcade Expression
844
01-12-2022 09:54 AM
AshleighReeves
I am trying to write a formula similar to the one below but with the option to say if within 1 standard deviation above or below then well below average or well above average. I am able to successfully get the equation to say just above or below. But how do I get the standard deviation portion?
var youth= $feature.MINOR_PERCENT;
IIf(youth < Average($layer, 'MINOR_PERCENT'), 'below average', 'above average');
jcarlson
There is actually a function for returning the standard deviation of a given set of values. Once you have that, you can just compare the individual feature's value with the mean and see if it falls outside of that range.
var lyr = $layer;
var lyr_mean = Mean($layer, 'MINOR_PERCENT');
var lyr_stdev = Stdev($layer, 'MINOR_PERCENT');
var youth = $feature.MINOR_PERCENT;
var deviation = Abs(lyr_mean - youth);
if(deviation > lyr_stdev){
    return 'Greater than 1 standard deviation'
} else {
    return 'Less than 1 standard deviation'
- Josh Carlson
Kendall County GIS
