GROUPED DISPLAY IN BAR CHART
2035
01-16-2025 02:50 AM
jantolihao
Hi, everyone!
I have configured a dashboard where one of the elements is a bar chart of count of application status. Please see screenshot below.
However, I want to group these statuses to only 3 groups: Active, Approved, and Released in the DASHBOARD LEVEL. Please see screenshot of preferred output.
Although, I understand that adding another field for Status Group (where values are only Active, Approved, and Released) can solve this concern, but this solution is NOT an option since we are not allowed to add another field since the data is not ours and can only consume the layer view (non-hosted).
Is there a way to do this using expression? I appreciate any hints on this. Thank you very much.
DfIRivers
Apply a Filter to your Bar Chart, and you should be able to just pull through the  Status that you want to include.
KenBuja
MVP Esteemed Contributor
In a Data Expression, you can use the GroupBy function with a case expression in the SQL statement to return a FeatureSet with a calculated field. It would look something like this (not knowing how you want the original statues reclassified)
var fs = FeatureSetByPortalItem(
  Portal("your portal"),
  "itemID",
  0,
  ["Status"],
  false
var sql_statement = `CASE
WHEN STATUS = 'PENDING' OR STATUS = 'FINAL-PROCESS' THEN 'Active'
WHEN STATUS = 'FINAL-APPROVED' OR STATUS = 'PRELIMINARY-APPROVED' THEN 'Approved'
WHEN STATUS = 'SUCCESS' THEN 'Release'
ELSE 'Other'
END`
GroupBy(
  fs,
  { name: "Status", expression: sql_statement, statistic: "COUNT" },
  { name: "Total", expression: "1", statistic: "COUNT" }
jantolihao
Hi, @KenBuja.
Thank you very much for this data expression. I was able to apply it on my dashboard.
However, I am having difficulty in adding my category selectors. I need to filter this bar chart by Application No. and Person Applied. Did you happen to encounter something like this before?
KenBuja
Don't forget to click the "Accept as Solution" button on the post.
Have you added those fields to the FeatureSetByPortalItem and the GroupBy functions?
