Find web map consumed by Dashboard
2183
03-01-2024 07:14 AM
PLadd
Suppose someone has a dashboard with a web map in it. Suppose someone wants to edit the web map in the dashboard. How does one determine which of the dozens of web maps on the Content page of Portal is the one being consumed by the Dashboard?  None of the properties on the Dashboard page have a property that points to the web map in use.
dolson_farmington
It's not an intuitive spot at all, but if you click the three lines to the left of the Dashboard header, it lists the maps you have in your dashboard and you can click on them and it will navigate you to the map in your portal:
dolson_farmington
PLadd
Thanks @dolson_farmington !  That's very helpful.
For others looking at this solution, if it helps, note my interface looks slightly different:
