Find my Location widget
1518
10-02-2023 07:47 AM
SLouq
by MVP Alum
How can I edit the Find my Location widget in my dashboard? I am using the Capital Projects Tracking solution and it has a widget in the capital projects web map for Find my location which when I click on it doesn't go to my location. Is this widget editable so I can change the address it goes to?
Tags (1)
IssyAmis
Hi @SLouq
To check my understanding of your question, by "Find my location" widget, do you mean the button within the map widget that zooms to your location? If yes, could you confirm that the device you are using has access to your location?
Issy
IssyAmis
Hi @SLouq
Issy
SLouq
by MVP Alum
Thanks for the reply IssyAmis!
So that button zooms to the default location stored within my computers location profile.
I will check my computer's location profile to see if that is the same location it has set.
Thanks!
