Filter map on Select using CONTAINS instead of an exact match in ArcGIS Dashboards
2349
6
08-02-2024 08:29 AM
apgis16
Is there a way to filter the map layers upon a select (in the web map) using contains instead of an exact match of a field in ArcGIS Dashboards?
jcarlson
Unfortunately, using filter actions between widgets needs an exact match. Experience Builder lets you use a "contains" filter, but I know it's not always the right choice. What's your use case? Is using EB instead of dashboards an option?
- Josh Carlson
Kendall County GIS
apgis16
I want to be able to filter the map by outfall designation upon select. However, some storm mains, manholes, and inlets have multiple outfall designations in the field ("OF1-OF2-OF3").
jcarlson
Yeah, there won't be an easy way to do that. If you really want to use a Dashboard, you might be able to use a Data Expression to sort of "break apart" the field. Getting it to interact with the map would be tricky, though.
- Josh Carlson
Kendall County GIS
apgis16
Is there a way to do it in Experience Builder? I didn't think so since it doesn't have arcade (yet..)
jcarlson
Experience Builder's Filter widget lets you do "contains", so there'd be no need for any fancy expressions.
- Josh Carlson
Kendall County GIS
apgis16
Can you make it filter on select within the map? Instead of using the filter widget.
