Feature layer not visible to add to dashboard
1317
10-14-2023 01:54 PM
JohnMorgan
I have a Feature layer (hosted) that I created by publishing from ArcGIS Pro as a web layer. I can see and view it on my content. However, whenever I create a new Dashboard and go to Add > Map it is not visible as a map to select. I have already adjusted the sharing from the Owner, organization, and even Everyone (public), but none of those options made it available to add to my dashboard. Any help/tips would be greatly appreciated.
Derek
JohnMorgan
It seems I was able to get the layer to be visible to the dashboard with the following steps, though I am not sure it was intuitive from the documentation:
Once you have a Feature Layer (hosted) by YourUserName, you will want to Open in Map Viewer ClassicSet Visibility Range (three dots next to layer name), and then Save it to make it visible to your dashboard
In case anyone else has same issue.
