Error in Filter when creating Arcade Data Expression
3708
03-30-2023 07:09 AM
ZachLansford_HD
Hi everyone,
I am trying to create a Data Expression within my dashboard to access some related records. I've set up a filter to access the data but am getting an error when trying to access the data from the Filter.
"Test execution error: Unknown Error. Verify test data."
I've added a few console outputs to test my results. I am able to get the output for the first console statement but then run into the error.
I've added the relevant portion of the script below.
var portalServ = Portal("https://www.arcgis.com/");
var pointFS = FeatureSetByPortalItem(
  portalServ,
  "featID",
  0,
  False
var tablefs = FeatureSetByPortalItem(
  portalServ,
  "featID",
  1,
  False
var features = [];
var feat;
var calls_sub_found_var;
for (var t in tablefs){
  var TableID = t["op_record_id"]
  console(TableID);
  for (var p in Filter(pointFS,"op_record_id = "+Text(TableID))){
    console(p["op_record_id"]);
Additionally, if I use the console to output the Filter object itself, I am able to return that. It is only when I try and start accessing the objects from the filter when I run into the error.
Would the amount of data be a factor in the filter failing? I'm working with ~120k point features and ~20k related records in total.
KenBuja
MVP Esteemed Contributor
Is op_record_id field a string field or numeric? If it's a string, you'll need quotes. Or you can avoid that by using @variable
var TableID = Text(t["op_record_id"]);
for (var p in Filter(pointFS,"op_record_id = @TableID")){
KenBuja
ZachLansford_HD
It is a string field - this solved my issue. Thanks a bunch!
jcarlson
When you return the filtered object, what does it look like?
When I write a filter statement, I prefer to use template literals:
Filter(pointFS,`op_record_id = ${TableID}`)
In general, when you're working with a filtered FeatureSet, you ought to include an if statement that checks to see that there are any features. Expressions can sometimes break when they attempt to work with a FeatureSet that has nothing in it.
var filtered = Filter(...)
if (Count(filtered) > 0) {
  for (var p in filtered) {
Is there a real relationship class between the layers? Why not use FeatureSetByRelationShipName?
- Josh Carlson
Kendall County GIS
