Elements tied to multiple maps
936
11-16-2023 05:20 PM
aprhyde11
Hi!
I’m working on creating a dashboard with multiple map elements. I also have indicators, lists, and gauges. I know it’s possible to connect multiple maps to each element i.e. if I select a different map the elements update along with it. But I’m having trouble figuring it out.
Any help is appreciated!
IssyAmis
Hi @aprhyde11
Thanks for your question.
I believe this should be possible but I just want to check my understanding of what you are trying to achieve. Is it that you have the same layer in a few of your maps and would like to use any of the maps to, for example, filter down your list widget when you pan around the map?
If this is not the case and you don't have a similar layer in your maps, then this might be slightly more complex. I don't believe there is a way to get your dashboard elements to change which layer they are looking at depending on the map selected, but I can look into this if this is what you are doing.
Let me know and I will be happy to assist further!
Thanks, Issy
