Editing is not possible because the globalId parameter was not provided - trying to have users edit records with embedded survey
12061
19
08-09-2023 08:34 AM
dwold
I get this error when embedding my survey into an embed element: Editing is not possible because the globalId parameter was not provided
URL I am using: https://survey123.arcgis.com/share/e1b5cc74f6b5454088f925fcef4bc6d2?mode=edit&globalId={globalid}
@JohannesLindner
@KenBuja
@DougBrowning
DougBrowning
MVP Esteemed Contributor
dwold
@DougBrowning  thanks for the feedback. I also saw this post and ensured both were enabled on the survey and hosted feature layer.
I created the survey in Connect from an existing hosted feature layer. Do you know if that would be causing an issue?
DougBrowning
Does it have related tables?  If so then you may not have the proper parentglobalisd and such.
dwold
@DougBrowning no, just a standard hosted feature layer. I was able to do this process on a previous dashboard and set this dashboard up using the same steps. For some reason, this one is throwing me that error. Very bizarre.
DougBrowning
Hmm I wonder if since it was a existing layer you have to set the security on the items page of the service.  Does that all look good?  And the service has globalids enabled?  These are usually added before you publish.
Sorry that is about all I got.
dwold
@DougBrowning no worries, I've enabled the sync setting in the item details and ensured globalids are enabled. Just strange behavior in the dashboard. Thanks for your suggestions. I'll keep poking around to see what might be the issue.
Martin1
Hello,
Did you ever find a solution for this problem?
I am seeing the same error with a Survey123 integrated in an Experience Builder application.
DavidMcCorkindale1
I'm also experiencing this issue in Experience Builder, did anyone ever find a solution?
Thanks.
Martin1
We opened a ticket with ESRI Support and the issue got logged as BUG-000163913 : "In ArcGIS Experience Builder, the embedded survey is not editable and returns the following error message, "Editing is not possible because the objectId parameter was not provided." after changing the linked web map in ArcGIS Survey123 Connect."
