Download Data From Expression
1518
07-14-2023 03:13 PM
ry
On my dashboard, I'm using a data expression to generate a feature set that I then use to populate a list element. Everything works great, except that I can't seem to be able to find out how to enable source data download. I want to be able to export the data generated in this list element. It works fine with all other elements, just not with the one generated from a data expression. I've enabled exporting on all layers, I'm stumped. Maybe it's not possible, or I'm missing something. If it's not possible, are there any plans on making this possible in the future?
Juan_FelipeVillegas
i have exactly the same situation.
I have created a data expression with different feature data sets and i have created a table in arcgis dashboard with those data.
Is it possible to export that table as a csv file?
Did you find a solution for that?
Regards.
