Displaying symbology dynamically based on date Expression Builder
644
11-13-2025 10:16 AM
OmoOyaks
I am fairly new to Arcade and having trouble understanding why the symbology expression builder to display the date attribute isn't working. I created an Arcade expression to display attributes based on their expiry date attribute.
Feature name - Defib, Feature attribute - Expdate
It does seem to display the different if cases, but the dates displayed are all wrong.
For example, a map feature is displayed as expired but the actual expiry date is in 7 months. The date format is mm/dd/yyyy
See attached expression, I am at a loss what the problem is.
if (DateDiff(Now(), Date($feature.Expdate), 'days') <= 0) {
return "Expired" }
else if (DateDiff(Now(), Date($feature.Expdate), 'days') <= 30) {
return "Expires within 30 days" }
else if (DateDiff(Now(), Date($feature.Expdate), 'days') > 30 &&
DateDiff(Now(), Date($feature.Expdate), 'days') < 100) {
return "Expires between 30 to 100 days" }
else if (DateDiff(Now(), Date($feature.Expdate), 'days') >= 100) {
return "Expires in more than 100 days" }
else {
return "Expiry Date Unavaliable" }
KenBuja
MVP Esteemed Contributor
You have the order of the DateDiff parameters reversed if the ExpDate is in the future. For those dates, your expression returns a negative number.
Here's an easier way to write your expression, using the When function. This assumes that the ExpDate field is a date field.
if (IsEmpty($feature.Expdate) return "Expiry Date Unavailable"
var diff = DateDiff($feature.Expdate, Now(), "days");
When(diff <= 0, "Expired",
     diff <= 30, "Expires within 30 days",
     diff < 100, "Expires between 30 to 100 days",
KenBuja
OmoOyaks
Thank you, that worked.
