Dictionary to FeatureSet issues. Probably the dictionary format?
1174
10-25-2024 12:49 AM
BlakeMorrison
I'm struggling to work out what I'm doing wrong trying to convert this Dictionary to a FeatureSet. I'm getting an invalid parameter error.
var fs = FeatureSetByPortalItem(
    portal,
    id,
    0,
    fields,
    False
var combinedFeatures = [];
for (var f in fs) {
        Push(combinedFeatures, {
            "Variety": f["variety1"],
            "Area": f["var1_perc"]
            "Variety": f["variety2"],
            "Area": f["var2_perc"]
            "Variety": f["variety3"],
            "Area": f["var3_perc"]
var schema = { fields: [
    { name: "Variety", type: "esriFieldTypeString" },
    { name: "Area", type: "esriFieldTypeSmallInteger" }
var d = Dictionary(Text(combinedFeatures, schema));
Console(d)
return FeatureSet(d)
My dictionary, as shown by Console(), looks like this:
{"0":{"Variety":null,"Area":0},"1":{"Variety":null,"Area":0},"2":{"Variety":null,"Area":0},"3":{"Variety":null,"Area":0},"4":{"Variety":null,"Area":0},"5":{"Variety":null,"Area":0},"6":{"Variety":null,"Area":0},"7":{"Variety":null,"Area":0},"8":{"Variety":null,"Area":0},"9":{"Variety":null,"Area":0},"10":{"Variety":null,"Area":0},"11":{"Variety":null,"Area":0},"12":{"Variety":null,"Area":0},..............
KenBuja
MVP Esteemed Contributor
I believe what you're trying to do would be like this
    portal,
    id,
    0,
    fields,
    False
for (var f in fs) {
  Push(
    combinedFeatures,
    { attributes: { Variety: f["variety1"], Area: f["var1_perc"] } }
  Push(
    combinedFeatures,
    { attributes: { Variety: f["variety2"], Area: f["var2_perc"] } }
  Push(
    combinedFeatures,
    { attributes: { Variety: f["variety3"], Area: f["var3_perc"] } }
var combinedDict = {
  fields: [
    { name: "Area", type: "esriFieldTypeInteger" }
  geometryType: "",
  features: combinedFeatures
var d = Dictionary(combinedDict);
Console(d);
return FeatureSet(d);
CodyPatterson
MVP Regular Contributor
Hey @BlakeMorrison
Could you try replacing your var d with this here and then console/return it:
var featureSet = FeatureSet(Text(combinedFeatures), schema);
I'm wondering if there is a difference between the dictionary and its current formatting, and the creation of the FeatureSet, as schema looks properly placed together, but combinedFeatures may need moved to Text.
Cody
KenBuja
    portal,
    id,
    0,
    fields,
    False
for (var f in fs) {
  Push(
    combinedFeatures,
  Push(
    combinedFeatures,
  Push(
    combinedFeatures,
  fields: [
  geometryType: "",
Console(d);
