Decimal points in list
706
12-17-2025 10:12 AM
KerrieYoungs
I was hoping I could get some help.
I have built a dashboard in ArcGIS online with list element that displays a number field.  this number field has only one decimal point and in edit mode this is all that shows up and it looks sweet.  However then in the published dashboard the field now displays with 2 decimal points.  All the data tables have this information with no decimal place.  I don’t have pop-ups enabled on the map or the dashboard.  Are you able to help me make this to be a whole number?
Neal_t_k
MVP Regular Contributor
For a list I believe you have to format that in the layer like you would for a pop-up on a web-map.  If it was a table you could use advanced formatting.
Open that layer in a map the open the properties for that layer, click the fields tab in the properties and then select the field you want to round. There should be options for how many decimal place you want to see.
Be sure to save the layer after you are done;  Three dots menu for that layer, then save.
