Date Selector Clearing All Layers in Map Element
748
03-13-2025 01:57 PM
Labels (2)
KathrynWesson
I published a service with multiple layers from the same data source (but filtered differently), plus a couple of other layers from another source that have the other layers' source table joined to them.
When I set up the filter action through the date selector and point the target field to the joined table's date field, it ends up filtering out all of the layers from the map element. The only compromise I have found to get the date selector to stop clearing all the features from the map element when triggered, is by pulling the map image layer item IDs into Map Viewer one at a time. However, this gets rid of the symbology I defined in ArcGIS Pro, which is not ideal.
I'm including a recording of what happens when I apply the same date range in both test dashboards. *First dashboard has the map image layer added as-is, and the second dashboard has each map image layer item ID added separately. Everything else is set up exactly the same between the two test environments.
Is this a bug or am I doing something wrong?
