Data Not Appearing in Dashboard Table
4318
6
06-03-2024 12:06 PM
AndrewParr
Hello,
I made a Dashboard that is intended to be used to centralize data in one place for ease of access for people less familiar with GIS. I created a table that has a few of the mapped fields, but two of the fields are showing no data in the table. In the actual data table, every entry has data in these fields so there is no real reason for them to be blank. The only difference between these fields and any of the other fields is that they use small integer values, and the rest of the table uses string values.
Any help would be appreciated.
KassieKM
I am having this same issue. Did you figure out a solution?
Bec
Andrew,
Can you submit some images of what your table looks like in the dashboard and what the table should look like?  Also, can you submit images of the field view so people may see what the settings are for the fields that are missing data?  This will hopefully help myself or others see the issue and maybe find the solution.
Bec
AndrewParr
I replied to the original post with photos. Hopefully they can help. 😁
AndrewParr
Here are photos to try and help solve this issue. I am not entirely sure I got the correct field settings in the photos, so if something else is needed, let me know.
Screenshot (1).pngScreenshot (2).pngScreenshot (3).pngScreenshot (4).pngScreenshot (5).png
KassieKM
JasonBrown
I am experiencing this issue as well. Here is a screenshot of my table in the Backflow Inspections dashboard. These records are all fully populated, but do not display as such.
CascadeDiver
I was having the same issue. When looking through everything I noticed that the Advanced Formatting values was on, which I intended. However, I had enabled advanced formatting prior to adding certain columns and those newly added columns were not in the advanced formatting script. I turned advanced formatting OFF and then back ON again. The result being that the script was refreshed all columns of data. Unfortunately I had to reapply any custom formatting I had previously written.
