Data Expression unable to run Arcade Script Error
1485
05-23-2024 09:24 AM
JaronJensen7
I have a dashboard where I am inserting an indicator. My indicator is looking at a layer and is working fine. I want to edit my reference layer to combine some data from two different layers. I am using the data expression option to create some arcade code to return the value that I want. I have gotten it to work in the arcade editor, but when I save the code and try to make it my reference layer it says "Unable to execute Arcade Script."
The layers that I am trying to reference are part of a layer group. But it seems to work fine when it is in the editor and grabs the right data.
Any ideas on what I can try?
KenBuja
MVP Esteemed Contributor
A Data Expression needs to return a FeatureSet, not a variable. Replace line 11 with this
var theDict = {
  'fields': [{ 'name': 'result', 'type': 'esriFieldTypeInteger'}],
  'geometryType': '',
  'features': [
      'attributes': {
        'result': Text(Round(fiber_total),'#,####')
return FeatureSet(theDict);
KenBuja
var theDict = {
  'geometryType': '',
  'features': [
      'attributes': {
JaronJensen7
@KenBuja Thank you that worked! I did have to get rid of the Text() function cause it seemed to be returning the number of characters. Once I did that it did give me my value that I wanted!
