Data Expression To Return Most Recent Date for Hydrant Inspection in Dashboard Indicator
3384
10
04-23-2025 08:47 AM
MelanieBass
I have a hydrant inspection layer that I have configured a dashboard for and I am trying to get the indicator widget to reflect the correct number of hydrants still needing inspections. Currently the number is inflated because there are multiple inspections per hydrant. I have been working on trying to create a data expression to create a FeatureSet to filter most recent inspections per hydrant, but I am having no luck. Every code I have tried multiple code combinations, and it just returns an empty dataset.
// Load the hydrant inspections layer
var inspections = FeatureSetByPortalItem(
Portal("https://maps.casselberry.org/portal"),
"f3a4a8879ce34241a5fd139ddfaf727a", // Inspection Layer Item ID
var maxDate = Text(Date(Max(fs, 'dateinspected')), 'YYYY-MM-DD');
return Filter(fs, 'dateinspected = @maxDate');
This code is based on this github post I had found
KenBuja
MVP Esteemed Contributor
To get the latest inspection for all of the hydrants, this code should work. Make sure you change the name of 'HyrantID' to the correct field name
GroupBy(inspections , 'HyrantID', {name: 'Latest', expression: 'dateinspected', statistic: 'MAX'})
KenBuja
The dataset in the Github repository example has that date in a text field, not a date field. If your field is a date field, you can do this much easier using the OrderBy and First functions
return First(OrderBy(inspections, "dateinspected DESC"));
MelanieBass
Thank you for your prompt response! I tested it and it appeared to work till I clicked done and then got this.
KenBuja
Ah, I forgot the first rule of Data Expressions...always return a FeatureSet.
This should work
var feat = First(OrderBy(inspections, "dateinspected DESC"));
var dict = { fields: Schema(inspections ).fields, features: [feat] };
return FeatureSet(dict);
MelanieBass
Unfortunately still not working..
Will this code return most recent for EACH hydrant not just most recent inspections done for all hydrants? so most recent inspection per hydrantid.
KenBuja
Are you using an older version of Enterprise? If so, you'll have to use
return FeatureSet(Text(dict));
And yes, this code only returns the most recent inspection.
KenBuja
MelanieBass
OMG this worked! Thank you soooo much! I have been going crazy with this code for days! I appreciate it!
MelanieBass
@KenBuja Your code that you gave worked beautifully however, I have now some hydrant inspections that have defaulted the null value for date 12/30/1899 and I also need those to return in the feature set. Is this possible with editing your original code?
KenBuja
You can add multiple statistics to the GroupBy function. This will return the latest and earliest inspections for each hydrant. However, this does not include dates that are null
GroupBy(inspections , 'HydrantID', [{name: 'Latest', expression: 'dateinspected', statistic: 'MAX'},{name: 'Earliest', expression: 'dateinspected', statistic: 'MIN'}])
