I have the following dashboard data expression that looks at the results (view) of a Survey123 form and groups by Truck Number and does some basic addition. The Survey123 form displays fields based on a parameter URL. Each station, such as Fingers 1, Barrel, or Plow Drop, has a QR code that determines the fields that judges see. All of the results are populated into a single HFL. We can can calculate a Total Score field using ArcGIS Pro but we would like for this to be dynamic in a Dashboard.
var fs = FeaturesetByPortalItem(
Portal("https://cohgov.maps.arcgis.com"), // your Portal's url
"b8411078d5fc40c9b65012fe72e02a4d", // the service id
0, // the sub-layer id
['Truck_No', 'Fingers1', 'Fingers2', 'Fingers3', 'Barrel', 'Serpentine', 'AlleyDock', 'StreetOffset', 'Mailbox', 'TirePush', 'PlowDrop'], // the fields you want to load
false // do you want to load geometries
return GroupBy(fs, ['Truck_No'],
{name: 'Fingers1score', expression: 'Fingers1', statistic: 'SUM' },
{name: 'Fingers2score', expression: 'Fingers2', statistic: 'SUM' },
{name: 'Fingers3score', expression: 'Fingers3', statistic: 'SUM' },
{name: 'BarrelScore', expression: 'Barrel', statistic: 'SUM' },
{name: 'SerpentineScore', expression: 'Serpentine', statistic: 'SUM' },
{name: 'AlleyDockScore', expression: 'AlleyDock', statistic: 'SUM' },
{name: 'StreetOffsetScore', expression: 'StreetOffset', statistic: 'SUM' },
{name: 'MailboxScore', expression: 'Mailbox', statistic: 'SUM' },
{name: 'TirePushScore', expression: 'TirePush', statistic: 'SUM' },
{name: 'PlowDropscore', expression: 'PlowDrop', statistic: 'SUM' },
// Add a new aggregation to sum all the score fields
expression: 'Fingers1 + Fingers2 + Fingers3 + Barrel + Serpentine + AlleyDock + StreetOffset + Mailbox + TirePush + PlowDrop',
statistic: 'SUM'
)The featureset looks decent.
I'm running into two issues:
Any suggestions from the Esri Community?
Thank you!
Solved! Go to Solution.
Thank you for your responses! We got it to work using the code below. This was created using a combination of your responses and fed into Gemini and Copilot.
var fs_clean_features = [];
// Define the fields for the new featureset structure
var fields_to_include = [
{ name: 'Truck_No', type: 'esriFieldTypeString' },
{ name: 'Fingers1', type: 'esriFieldTypeDouble' },
{ name: 'Fingers2', type: 'esriFieldTypeDouble' },
{ name: 'Fingers3', type: 'esriFieldTypeDouble' },
{ name: 'Barrel', type: 'esriFieldTypeDouble' },
{ name: 'Serpentine', type: 'esriFieldTypeDouble' },
{ name: 'AlleyDock', type: 'esriFieldTypeDouble' },
{ name: 'StreetOffset', type: 'esriFieldTypeDouble' },
{ name: 'Mailbox', type: 'esriFieldTypeDouble' },
{ name: 'TirePush', type: 'esriFieldTypeDouble' },
{ name: 'PlowDrop', type: 'esriFieldTypeDouble' }
for (var f in fs) {
var newFeature = {
attributes: {
Truck_No: f['Truck_No'],
// IIF(IsEmpty(f['FieldName']), 0, f['FieldName']) ensures the result is a number (0) or the original number.
Fingers1: IIF(IsEmpty(f['Fingers1']), 0, f['Fingers1']),
Fingers2: IIF(IsEmpty(f['Fingers2']), 0, f['Fingers2']),
Fingers3: IIF(IsEmpty(f['Fingers3']), 0, f['Fingers3']),
Barrel: IIF(IsEmpty(f['Barrel']), 0, f['Barrel']),
Serpentine: IIF(IsEmpty(f['Serpentine']), 0, f['Serpentine']),
AlleyDock: IIF(IsEmpty(f['AlleyDock']), 0, f['AlleyDock']),
StreetOffset: IIF(IsEmpty(f['StreetOffset']), 0, f['StreetOffset']),
Mailbox: IIF(IsEmpty(f['Mailbox']), 0, f['Mailbox']),
TirePush: IIF(IsEmpty(f['TirePush']), 0, f['TirePush']),
PlowDrop: IIF(IsEmpty(f['PlowDrop']), 0, f['PlowDrop'])
Push(fs_clean_features, newFeature);
// CRITICAL FIX: Explicitly pass the schema and features
var fs_clean = Featureset({
fields: fields_to_include,
geometryType: '', // No geometry
features: fs_clean_features
// Use fs_clean in the GroupBy function
return GroupBy(fs_clean, ['Truck_No'],
// The individual score fields are calculated using the clean data (0 instead of null)
{name: 'PlowDropScore', expression: 'PlowDrop', statistic: 'SUM' },
// TotalScore will now correctly sum non-null values (0 for originals nulls)
statistic: 'SUM'
)Screenshot of the finished Dashboard.
We have ideas for how we can improve for 2026!
Try something like this:
expression: 'DefaultValue(Fingers1, 0) + DefaultValue(Fingers2, 0) + DefaultValue(Fingers3, 0) + DefaultValue(Barrel, 0) + DefaultValue(Serpentine, 0) + DefaultValue(AlleyDock, 0) + DefaultValue(StreetOffset, 0) + DefaultValue(Mailbox, 0) + DefaultValue(TirePush, 0) + DefaultValue(PlowDrop, 0)',
statistic: 'SUM'
}This should set the value to 0 when the items are 'null'
for (var f in fs) {
var newFeature = {
attributes: {
statistic: 'SUM'
