Data Expression Needing to Return an Empty Feature Set
2618
05-08-2024 08:44 AM
AlinaTarmu_SCGIS
Is it normal behavior for a dashboard data expression to display "Unable to Execute Arcade Script" if it needs to return an empty feature set? When testing, the script executes as it should, it codes a dynamic indicator that at this point should display zero. Is there a workaround for this issue?
KenBuja
MVP Esteemed Contributor
Can you post your script? Does it return an empty FeatureSet or the number 0?
AlinaTarmu_SCGIS
It returns an empty feature set. I created another script that returns an empty feature set and that one indeed works fine (thanks, @jcarlson!). It might be something in the script (or data, or most likely portal).  Here it is:
// declaring portal variable
var portal = Portal("https://myportal.com/portal");
// filter work order feature set for required fields
var fs = Filter(
  FeatureSetByPortalItem(
    portal,
    '3f959g85g959595954ff9ggkdkgr',
    0,
    ["OBJECTID", "EQUIPMENT", "STATUS", "DATE_CREATED"],
    false,
  "STATUS LIKE 'Not Performed' AND PM_CODE LIKE 'SG-100SW-3'"
//generating an array of equipment values that have consecutive Not Performed cycles
var pairs = []
for (var r in fs) {
    var keys = r["EQUIPMENT"];
    var values = r["DATE_CREATED"];
    var keyvalue = {"key": keys, "value": values}
    Push(pairs, keyvalue)
var resultArray = [];
for (var i = 0; i < Count(pairs)-1; i++) {
  var current = pairs[i];
  var next = pairs[i + 1];
  if (Equals(current.key, next.key) && Abs(DateDiff(Date(current.value),Date(next.value), "days")) <= 93) {
    Push(resultArray, current.key);
//adding single quotes to the strings in the array so that the SQL filter recognizes them in order to match them to the equipment layer
var newFilter = [];
for (var i = 0; i< Count(resultArray)-1; i++) {
    var string = "'" + resultArray[i] + "'";
    newFilter[i] = string
var eqFilter = `EQUIPMENT IN (${Concatenate(newFilter, ',')})`
//filtering the equipment layer for the equipment values in the array
return Filter(FeatureSetByPortalItem(
    portal,
    'otmbd4968695gmb09fkv99vkvv',
    0,
    false,
eqFilter)
This script works perfectly for two other PM codes, with 31, respectively 62 days.
jcarlson
What is your expression actually returning? Can you share the code?
Returning an empty data expression is possible, and works just fine.
- Josh Carlson
Kendall County GIS
AlinaTarmu_SCGIS
Today my other two data expressions, which were working perfectly, display the same error. SO IT IS DEFINITELY NOT THE CODE. 😀  (This issue is related to the other issue I posted, with the chart built on a data expression not interacting with other dashboard elements, issue to which Josh answered.)
(Also: thank goodness for the Arcade Playground...)
