Dashboard number selector filtering out max value when it shouldn't.
1798
10-05-2023 02:37 PM
chenry_AIR
I have a dashboard that is filtering using a selector. I'm using a ranged slider that uses a statistic to get the limits. For some reason, the feature with the max value being used is being filtered out. No matter what I do, it is removing that feature. If the min and max values are being pulled from a field and there are no missing values, then no features should be removed unless the user changes the min or max value, right?
This selector is defaulting to removing the feature with the max value and I don't understand why. When I delete the selector, the feature appears.
BEFORE DELETE
AFTER DELETE
Any help would be really appreciated!
Andrew_Bartshire
Having this exact same issue. Took a long time to discover this was why my feature wasn't showing on the dashboard. This seems like a pretty serious bug because it gives incorrect results to end users that might be using these tools for decision making.
