Dashboard not creating Serial Chart with Features Category — Get "No Data" message, even though data exists.
1341
04-18-2025 05:30 AM
ThomasEdinger
The Serial Chart does not seem to work for Categories from Features option; I get a message of "No Data" even though data exists. I used this element in the past with no issues.  Is this a new bug?  Has there be change to this element recently?  See attached screen captures.
Thank you,
-tom
I apologize, but I was able to troubleshoot the problem.  How do I delete this ticket, if possible. If I can't please do.  Thanks.
KenBuja
MVP Esteemed Contributor
Instead of deleting the question, can you post how you solved this? That might help others who have the same problem
ThomasEdinger
I solved this issue by making sure I added both a Category Field and  Series Field; again a user error and should have known better to include both fields.  Thank you.
