Dashboard Indicator with Reference and Advanced Formatting
934
03-11-2025 09:42 AM
aprhyde11
I'm needing to add the Estimated, Actual, and Differences for my data in an Indicator.
Under the Data tab, I have the Actual Cost set up as a reference to the Estimated Cost. Everything works fine unless the Actual Cost is Null, in that case the Indicator reads "No Data". I need it to read the Estimated Cost: $###, Actual Cost: $0 , and Difference: $0
This is the expression I'm using:
var totalOverall = $datapoint.SUM_TOTAL_OVERALL;  // Your default field
var totalRepairCost = $reference.SUM_TOTAL_REPAIR_COST; // Your alternate field
// If totalRepairCost (actual) is null or empty, set it to 0
var actual = IIf(IsEmpty(totalRepairCost) || totalRepairCost == null, 0, totalRepairCost);
// Round up to the nearest whole number
totalOverall = Ceil(totalOverall);
actual = Ceil(actual);
// Calculate the difference (set to 0 if actual is 0)
var difference = IIf(actual == 0, 0, Ceil(totalOverall - actual));
// Format the numbers with thousand separators
var formattedTotalOverall = Text(totalOverall, '#,##0');
var formattedActual = Text(actual, '#,##0');
var formattedDifference = Text(difference, '#,##0');
return {
  // Text for the "Estimated" value
  topText: 'Estimated: $' + formattedTotalOverall,
  topTextColor: '',
  topTextOutlineColor: '',
  topTextMaxSize: 'medium',
  // Only show "Actual" and "Difference" if actual is not 0
  middleText: IIf(actual != 0, 'Actual: $' + formattedActual, ''),
  middleTextColor: '',
  middleTextOutlineColor: '',
  middleTextMaxSize: 'large',
  bottomText: IIf(actual != 0, 'Difference: $' + formattedDifference, ''),
  bottomTextColor: '',
  bottomTextOutlineColor: '',
  bottomTextMaxSize: 'x-small',
  // Ensure no "No Data" message is shown
  noValue: false
I realize it's a bit overcomplicated at the moment, but it's working for the most part.
How do I get the Indicator to still show data when Actual Cost = Null?
Thanks for the help!
StephanieSimpson2
Hey, did you ever solve this? I'm having the same issue.
