Dashboard Indicator SVGs
2475
04-02-2019 08:56 AM
DanteLee
I've built a Dashboard in ArcGIS Online, and I'm in the process of migrating it to Portal. A lot of the indicator icons I've used in AGO aren't available in our Portal right now, so I thought about adding them into Portal as custom icons. Are the AGO icon SVGs listed somewhere for something like that to be done?
DerekLaw
Esri Esteemed Contributor
Hi Dante,
No, we don't publish a list of SVG icons used in Operations Dashboard, sorry. But as a workaround, you could right-click an icon and select inspect element to view an icon's SVG code.
Hope this helps,
