I have a Survey123 Connect, with Incident Choices, I recently added to Column B "LA_Activation" in Column C "Louisiana Activation 26"
On the survey they show up as an option, in the Layer the entries display.
When I go to my dashboard, I want to create a list and use either of these two as a filter. The previously added Incident Choices are there, but not the new one?
Solved! Go to Solution.
Hi @ScottJones1,
Please ensure the Category Selector in your Dashboard is set to "Features" rather than "Fixed Values" so it dynamically pulls the new LA_Activation entries from your data. If the issue persists, manually add the new choice to the Coded Value Domain in the Feature Layer's "Data" tab settings in ArcGIS Online.
https://doc.arcgis.com/en/dashboards/latest/create-and-share/selectors.htm
Hi @ScottJones1,
I think that may have been the issue, it was set to grouped values
