Dashboard - Expression Sum multiple Fields
6575
07-13-2021 03:21 PM
RickeyFight
I am trying to sum our plant production from multiple sources.
var portal = Portal("");
var fs = FeatureSetByPortalItem(
  portal,
  1,
    "Date_",
    "W_F_MGD",
    "E_F_MGD",
    "TOTAL_W_E_MGD",
    "TID_FLOW_MGD",
    "REEDER_Percent_FULL",
    "TAP_FLOW_MGD",
    "PLANT_PRODUCTION_MGD"
  false
// Find the most recent date from the date field to filter the FeatureSet for the latest record
var TotalProduction = Round(Sum(fs, "PLANT_PRODUCTION_MGD")+Sum(fs, "TAP_FLOW_MGD"));
return TotalProduction;
I want to sum the TAP, TID, and Plant production fields.  I am getting errors even with the code above. What am I doing wrong.
Update:
using this I was able to sum in the script
https://www.esri.com/arcgis-blog/products/ops-dashboard/announcements/introducing-data-expressions-i...
Test shows a result but I cannot select it
DavidPike
MVP Notable Contributor
I'm guessing this is a data expression? The issue is that you have to return a featureSet.  I would just construct a simple feature set with the value you need as a single row.
https://doc.arcgis.com/en/dashboards/get-started/create-data-expressions.htm
https://doc.arcgis.com/en/dashboards/reference/authoring-data-expressions.htm
var newDict = {
  'fields': [{ 'name': 'totProd', 'type': 'esriFieldTypeDouble'}],
  'geometryType': '',
  'features': [{
            'attributes': {
                'totProd': TotalProduction,
return FeatureSet(Text(newDict));
DavidPike
var newDict = {
  'geometryType': '',
  'features': [{
            'attributes': {
SIG-EscutismoCNE
Hello,
I’m trying to write an expression in the dashboard to add two layers in a certain field (n_lobitos in both)
I’m not getting it. Any help?
I’ve seen the sample below but it’s different.
https://github.com/Esri/arcade-expressions/blob/master/dashboard_data/CalculationAcrossFields.md
var portal = Portal('https://www.arcgis.com/')
var fs = [
  FeatureSetByPortalItem(portal'8fadffa6772f428db8ffa703f9ebc61b'layerID, ['n_lobitos'], false),
  FeatureSetByPortalItem(portal'43e99df1123d454cb3d3e48ae5cfa462'layerID, ['n_lobitos'], false),
var running_sum = 0
for (var set in fsets) {
  var set_sum = Sum(fsets[set], 'n_lobitos')
  Console('featureset sum:'set_sum)
  running_sum += set_sum
  Console('running sum:'running_sum)
return FeatureSet({
  fields: {name'sum_n_lobitos'type'esriFieldTypeInteger'}, // or whatever field type it is
  geometryType'',
  features: [{attributes: {sum_n_lobitosrunning_sum}}]
