Dashboard Displays Incorrect ObjectID
5367
16
07-18-2019 01:34 PM
joerodmey
I have a dashboard that consumes one feature service (created from Survey123) with 4 copies of it with different filters and different symbology assigned to each. I also have a list in this dashboard.
When I click on a record in the list, everything works fine including a popup that displays with the correct objectID. When I click on this exact same point in the map that is within the dashboard, it shows some random objectID. For example an ID I have in the list is 304, but when I click on it in the map it says 213.
Why would this be the case?
Any ideas Derek Law
DerekLaw
Esri Esteemed Contributor
Hi Joe,
Are you certain that you've clicked on the same feature in the map - as the item in the list? Are there overlapping point features in the map and perhaps you've clicked a different point/survey?
Any chance you could share the Dashboard so I can observe the behavior?
joerodmey
I have clicked on the identical feature in booth the list and map. There is only one feature service being consumed in the map. Sure what is your AGOL username I should share with?
DerekLaw
Hi Joe,
Can you please also post some screenshots of the behavior you're seeing so I know what to look for?
My ArcGIS Online login is Derek Law (Law).
joerodmey
The first image shows the list with #304. Once I click on it the map pans and pulls the popup for #304 (picture 2). When I click in the map on the same point the poup shows #132 as shown in picture 3. Derek Law
joerodmey
I've narrowed it down to the refresh interval. When its on this error persists. when I turn it off the issue disappears. Any known bugs? Derek Law
DerekLaw
Hi Joe,
I'm glad to hear that you've seemed to have determined the cause. No, there is no known bug for this behavior that I'm aware of. Can you please contact Esri Tech Support and open a ticket? Please provide detailed repro steps so they can examine this behavior and investigate further.
joerodmey
Do you have a specific contact in mind?
DerekLaw
Hi Joe,
No, I don't have a specific person in mind.
joerodmey
There is a documented bug: BUG-000121810
