Dashboard Chart Widget Broken
1117
04-01-2020 08:12 AM
BenjaminMittler
With this latest update to ArcGIS Online I now have charts on my dashboard that arent working. This is a dashboard that hasnt been touched in months and was working up until yesterday. Does anyone have any reasoning for this?
DerekLaw
Esri Esteemed Contributor
Hi Benjamin,
Which chart type: serial or pie charts? Can you please elaborate more - are they not loading? Is the data they're reporting not correct? Can you provide some screenshots?
I personally haven't observed any issues in the dashboards I've seen this morning.
EDIT: I just noticed you posted a similar topic thread under the Web AppBuilder for ArcGIS section,
https://community.esri.com/message/919255-re-dashboard-theme-infographic-widget?commentID=919255%23c...
Is your issue for ArcGIS Dashboards or for Web AppBuilder (using the dashboard theme, infographic widget)?
Hope this helps,
BenjaminMittler
Hey Derek,
You are correct, its webapp builder. that other topic is mine, I should delete this one. Ive been working with dashboards recently and forgot this one wasnt truly a dashboard.
Regarding the webappbuilder, its multiple types of charts, bar/pie at the least.
It seems i have narrowed the exact issue. If you choose to Display Attribute values as a chart and select to sort by Label the  inforgraphic will not work. Sorting by value does work, but this is annoying if you are trying to show progression over time.
