Dashboard Arcade sum statistic expression for two fields in same layer
1134
01-14-2024 12:59 AM
LisaLisa
Working an operational dashboard to show working progress
I need an arcade expression for Dashboard that applies statistic SUM for fileds: Printed_Co & Digita_Co that are Rdy for PickUp or Complete/Delivered.
The result will be displayed in an indicator in the dashboard.
My arcade expression is like this:
// Reference layer using the FeatureSetByPortalItem() function.
var fs = FeatureSetByPortalItem(Portal('https://my-site.pr.portal'), 'b19q57894c8521f58e68t87412' , 0, ['Printed_Co', 'Digital_Co], false);
var sumPrintedCo = Sum(Filter($feature, Status in ['Complete/Delivered',  'Rdy for PickUp']), 'Printed_Co');
var sumDigitalCo = Sum(Filter($feature, Status in ['Complete/Delivered', 'Rdy for PickUp']), 'DigitalCo');
sumPrintedCo + sumDigitalCo
All I'm getting is: Invalid variable assignment
KenBuja
MVP Esteemed Contributor
In the FeatureSetByPortalItem function, you have to include the "Status" field on the fields parameter when getting the FeatureSet and you were missing a closing quote for the Digital_Co field. The Filter function uses a FeatureSet as an input. You also have to put quotes around your filter expression and the "in" operator uses parentheses, not brackets.
var fs = FeatureSetByPortalItem(Portal('https://my-site.pr.portal'), 'b19q57894c8521f58e68t87412' , 0, ['Status', 'Printed_Co', 'Digital_Co'], false);
var sumPrintedCo = Sum(Filter(fs, "Status in ('Complete/Delivered', 'Rdy for PickUp')), 'Printed_Co');
var sumDigitalCo = Sum(Filter(fs, "Status in ('Complete/Delivered', 'Rdy for PickUp')), 'DigitalCo');
