Custom configuration to Operations Dashboard
2806
04-12-2019 06:56 AM
Katie_Clark
MVP Regular Contributor
Hello,
I have run into a limitation with the category selector in operations dashboard, which is also described in this post: https://community.esri.com/ideas/15955-more-query-operators-for-the-category-selector-in-arcgis-onli...
Is it possible to customize the dashboard with WAB Developer Edition to manually fix this limitation? If so, how would I go about doing that?
Thanks for any insight.
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
DerekLaw
Esri Esteemed Contributor
Hi Katherine,
No, Operations Dashboard for ArcGIS is a different and completely separate product from Web AppBuilder for ArcGIS. The widget framework for Web AppBuilder does not apply to Operations Dashboard (which is not extensible). Sorry.
We are striving to continually improve Operations Dashboard and we'll consider your feedback on the category selector.
Hope this helps,
DerekLaw
Hi Katherine,
Hope this helps,
Katie_Clark
Thanks for clarifying, Derek. So there is no way to customize the dashboard beyond the WYSIWYG interface?
Best,
Katie
DerekLaw
Hi Katherine,
Correct. Please let us know if you have feedback/enhancement requests via the ArcGIS Ideas site.
Katie_Clark
Ok. Again, thanks for clarifying and for your quick response!
I look forward to whatever functionality enhancements will be implemented in future updates.
Best,
Katherine
Best,
Katie
