Hello -
I am working in ArcGIS Dashboards in ArcGIS online. I want to create an indicator (see example below) that will display the risk value (PR_EXHYDPAR) stored in the layer as the middle text, and the percentile rank associated with that value which is not stored in the layer as the bottom text. I am trying write arcade code within the Indicator Advanced Formatting option that will order the PR_EXHYDPAR field and create a var for rank, and then calculate percentile rank to use in the bottom text. Below is what I have so far but it says "Unable to execute Arcade script", but is not showing any errors. I am not very familiar with iterate statements so guessing there is an issue there. Thanks in advance for any suggestions.
// order the layer by existing hydraulic risk
var ordered = OrderBy("PR_EXHYDPAR DESC")
//rank projects by existing hydraulic risk
var rank = 0
// iterate over the ordered layer
for(var f in ordered) {
// increase the rank
rank++
//calculate percentile rank for existing hydraulic risk
var pctrank = (f.rank-1)/(Count($datapoint.OBJECTID)-1)
return {
textColor:'black',
topText: 'Existing Hydraulic Risk',
topTextMaxSize: 'medium',
middleText: $datapoint.PR_EXHYDPAR,
middleTextMaxSize: 'large',
bottomText: pctrank,
bottomTextMaxSize: 'medium',
An indicator's advanced formatting area doesn't have access to the source data in a way to actually execute this expression. What you'd need instead is to use a Data Expression to create an ad-hoc "layer", and calculate your percentiles there.
Is your indicator showing percentiles for a selected feature?
@jcarlson I was worried about that. I have put together the below data expression in the code box to select the fields I need from the layer and it works. I can use the below code in Pro to calculate rank, but not sure how to incorporate it into the Dashboard Data Expression. I would prefer to do this on the fly than add additional fields to my layer (There are 7 fields I need to create percentile ranks for).
var setfeatures = FeatureSetByName($datastore, "SNP_Project");
var ordered = OrderBy(setfeatures, 'PR_EXHYPDAR DESC')
var rank = 0
rank++
if(f.OBJECTID == $feature.OBJECTID) {
return rank
Can anyone provide guidance on how to do this?
var port = Portal('https://www.arcgis.com');
var fs = filter(FeatureSetByPortalItem(
port,'01610f3a8912467c8b06f4b223a6b5e1', 0,
['PROJECTID', 'PR_PROJNAME', 'PR_STATUS', 'PR_ORIGTOTCOST', 'PR_P6TOTCOST', 'PR_EXHYDPAR', 'PR_EXSTRPAR', 'PR_EXTOTPAR', 'PR_ALTHYDPAR', 'PR_ALTSTRPAR', 'PR_ALTTOTPAR', 'PR_REDHYDPAR', 'PR_REDSTRPAR', 'PR_REDTOTPAR', 'PR_TOTNOMSCORE', 'PR_TOTSCORE', 'PR_WAC', 'PR_SUBWATERSHED', 'PR_COMMUNITY1', 'PR_MODELDATE', 'PR_PARTOOLDATE', 'PR_SWIM_ONLY', 'PR_PART_ONLY', 'PR_NONDISTRICT', 'PR_STRPARDATE'],
false),
"PR_SWIM_ONLY='No' AND PR_PART_ONLY='No' AND PR_NONDISTRICT='No' AND (PR_STATUS='01. Submitted – Pending Review/Scoring' OR PR_STATUS='02. Scored' OR PR_STATUS='03. Advanced SW Planning' OR PR_STATUS='04. Design' OR PR_STATUS='05. Construction' OR PR_STATUS='07. Completed')"
var out_dict = {
fields: [
{name: 'projectid', type: 'esriFieldTypeString'},
{name: 'projname', type: 'esriFieldTypeString'},
{name: 'status', type: 'esriFieldTypeString'},
{name: 'origtotcost', type: 'esriFieldTypeDouble'},
{name: 'P6totcost', type: 'esriFieldTypeDouble'},
{name: 'exhydpar', type: 'esriFieldTypeDouble'},
{name: 'exstrpar', type: 'esriFieldTypeDouble'},
{name: 'extotpar', type: 'esriFieldTypeDouble'},
{name: 'althydpar', type: 'esriFieldTypeDouble'},
{name: 'altstrpar', type: 'esriFieldTypeDouble'},
{name: 'alttotpar', type: 'esriFieldTypeDouble'},
{name: 'redhydpar', type: 'esriFieldTypeDouble'},
{name: 'redstrpar', type: 'esriFieldTypeDouble'},
{name: 'redtotpar', type: 'esriFieldTypeDouble'},
{name: 'totnomscore', type: 'esriFieldTypeInteger'},
{name: 'totscore', type: 'esriFieldTypeDouble'},
{name: 'wac', type: 'esriFieldTypeString'},
{name: 'subwatershed', type: 'esriFieldTypeString'},
{name: 'community1', type: 'esriFieldTypeString'},
{name: 'modeldate', type: 'esriFieldTypeDate'},
{name: 'partooldate', type: 'esriFieldTypeDate'},
{name: 'strpardate', type: 'esriFieldTypeDate'},
{name: 'swimonly', type: 'esriFieldTypeString'},
{name: 'partonly', type: 'esriFieldTypeString'},
{name: 'nondistr', type: 'esriFieldTypeString'},
geometryType: '',
features: []
// Iterate over each feature in the layer
for (var f in fs){
Push(
out_dict['features'],
{attributes:
projectid: Text(f['PROJECTID']),
projname: Text(f['PR_PROJNAME']),
status: Text(f['PR_STATUS']),
origtotcost: Number(f['PR_ORIGTOTCOST']),
P6totcost: Number(f['PR_P6TOTCOST']),
exhydpars: Number(f['PR_EXHYDPAR']),
exstrpar: Number(f['PR_EXSTRPAR']),
extotpar: Number(f['PR_EXTOTPAR']),
althydpar: Number(f['PR_ALTHYDPAR']),
altstrpar: Number(f['PR_ALTSTRPAR']),
alttotpar: Number(f['PR_ALTTOTPAR']),
redhydpar: Number(f['PR_REDHYDPAR']),
redstrpar: Number(f['PR_REDSTRPAR']),
redtotpar: Number(f['PR_REDTOTPAR']),
totnomscore: Number(f['PR_TOTNOMSCORE']),
totscore: Number(f['PR_TOTSCORE']),
wac: Text(f['PR_WAC']),
subwatershed: Text(f['PR_SUBWATERSHED']),
community1: Text(f['PR_COMMUNITY1']),
modeldate: Date(f['PR_MODELDATE']),
partooldate: Date(f['PR_PARTOOLDATE']),
strpardate: Date(f['PR_STRPARDATE']),
swimonly: Text(f['PR_SWIM_ONLY']),
partonly: Text(f['PR_PART_ONLY']),
nondistr: Text(f['PR_NONDISTRICT']),
//Return populated out_dict as FeatureSet
var par = FeatureSet(Text(out_dict))
return par
