Configure Map Data Source Error
6215
9
05-11-2016 06:32 AM
AustinDoezema
I cant find any information on what this means
Not sure how to fix this.
ChristopherOlsen
Hi Austin,
It means your source is unavailable right now.  That could be that the data is disconnected or the service URL changed on the backend.  You can try opening the webmap in AGOL and making sure the layer is connected and working- and then resave the map.  Then try reopening OD and see if it comes in.
Chris
MiraEl-Koussa1
The map is working fine, but i am still getting this error ! ( same error as the post above)
ChristopherOlsen
The map may be working fine, but the data layer within it is not.  There's a couple of things you can check: 1. See if the same problem is reproducible in a new ops view. 2. Go to the Item details page for your webmap in your organization and see if the link to the data source works there.
MiraEl-Koussa1
I did ... same issue
deleted-user-M0V5-IqusbtS
Hi Mira - any luck getting this fixed?  I am having the same issue; feature service is working fine in web map but not available in widget configuration.
Any help is greatly appreciated-
Eric-
MiraEl-Koussa1
in our case, we removed all the items and republished again.
we were not able to define the issue; but it worked fine.
Thanks - I removed M values and republished; no issues now.  Thanks for your reply-
Eric-
by Anonymous User
Not applicable
For above shown layer user connection don't have an access to read/view,
Check for layer connection and feature permissions
http://desktop.arcgis.com/en/arcmap/10.3/manage-data/geodatabases/grant-dataset-privileges.htm
JorisSiermann1
Hi Austin,
you could check in ArcMap/layer properties of this particular service if you have enabled the "Geometry" field.
