Click on a map, charts update
2245
06-19-2019 10:44 AM
MarquesMunson1
Hello,
I would like to know how it's possible if I am to select a feature on a map, the other charts, indicators, etc update. Right now I have it so when I click on an item in a list, it will zoom to that feature, highlight and charts update. I would like to have it the other way around as well.
DerekLaw
Esri Esteemed Contributor
Hi Marques,
Yes, this is possible. You will need to set actions in the Map element, specifically on an operational layer.
Configure actions on dashboard elements—Operations Dashboard for ArcGIS | ArcGIS
Hope this helps,
DerekLaw
Hi Marques,
Hope this helps,
MarquesMunson1
Yes this helps! I think I was putting the action on the map itself, thinking it would work. It now works perfectly!
