Change font type on Dashboard
5407
12-07-2021 05:29 AM
DarrylHilton
Is there a way to change the font style from the default on a dashboard in Portal? Ideally for a whole dashboard to match branding of the wider website.
jcarlson
MVP Alum
For individual widgets, you can adjust the font by editing the source and adding a style tag with font elements. I often like to set certain widgets to a monospace font to keep numbers aligned nicely.
Of course, this only works for widgets whose text can be edited in this way. Other items, such as a dashboard header or the selectors, or font within a chart, cannot be adjusted so simply.
The problem you'll run into pretty quickly is that the dashboards all use a shared stylesheet. You can find them at https://your-portal-url/apps/dashboards/assets/ on your Portal machine, for reference, or look at them in your browser's developer tools.
But being a shared stylesheet, changing its contents will alter every dashboard. And even if you wanted to do that, updating your Portal will overwrite these changes.
Perhaps an Esri staff person can speak to this in more detail, but I don't believe it's possible to do this without getting into some ill-advised editing of your Portal assets.
Is it an option to recreate your dashboard in Experience Builder? There you would have greater freedom in the fonts used.
- Josh Carlson
Kendall County GIS
ve360
Hi! I'm trying to do it by the browser devtool but I have not been able to do it. Can you explain how to do it? Thank you so much.
