Can map layer selection tool be enabled by default?
2413
09-05-2019 11:02 AM
AdamMesser1
In Operations Dashboard, the Map Layer Actions enables a selection tool that is not active in the map by default. Is there any way to enable the selection tool by default? I have found a post indirectly asking this question and an idea related to this issue and was hoping Esri staff could clarify. Thanks.
DerekLaw
Esri Esteemed Contributor
Hi Adam,
This functionality is currently not possible in Operations Dashboard. Please vote for the enhancement request that you referenced, https://community.esri.com/ideas/15496
Hope this helps,
DerekLaw
Hi Adam,
Hope this helps,
AdamMesser1
Thanks Derek. Hopefully the idea will get the votes to allow enabling that functionality.
