Can i use 2 values in same indicator
2410
01-10-2024 03:31 PM
maherelayyan2
As u see in pic attached i want to show values of 2 types in same field , currently i use indicator
which show either high or very high , can u show both H and VH in the same indicator or other DB element ?
Thanks
JenniferAcunto
Are you trying to sum those two fields to display in an indicator? Or do you want both fields shown individually on the same indicator?
Both can be accomplished using the Reference Section. This blog shows how to do it. If you don't want to sum them together, just stop before you get to the Advanced Formatting part.
- Jen
maherelayyan2
Hi
 want to show 2 values (High and Very high ) in the same field on one indicator instead of using 2 indicator each for value , do u think that blog u mentioned can be useful ?
JenniferAcunto
Yes, just make one the data value and one the reference value and label them accordingly.
- Jen
ChrisH2
Hi @JenniferAcunto  is there an approach that you'd suggest if you wanted to sum the value of more than 2 fields in the indicator?  The approach in your blog doesn't seem to allow access to statistics for fields that aren't part of the widget configuration in the data options
- thanks
JenniferAcunto
More than 2 fields needs a data expression.
- Jen
