Background Color in Pop-ups in Dashboard
793
09-06-2022 11:35 AM
KellyKnapp35
I have a Dashboard with Lists and a map.  When using the “Dark” Theme, the pop-ups in my map have parts that are unreadable.  The pop-up is a “Text” component that is comprised of a copied table from Excel.  The gray colored background cells are NOT visible in my Dashboard.  (See images)
Pop-Up in Map
Pop-up in Dashboard
How can I format my pop-up to be compatible with the Dark Theme in Dashboards?  Will I have to use an Arcade expression for my table?  Thank you!
