ArcGIS Dashboard Dynamic Text
1171
06-17-2022 12:41 PM
MichelleShaffer
Is there an element you can use for dynamic text in ArcGIS Dashboard?
I would like to use an element to create dynamic text that will change when the user selects an item from a category selector. The text that I need displayed is a string field in a table that is already published to my content on ArcGIS online. Ideally, this element will have two dynamic sections of text that are linked to two different category selectors.
I see where there are elements that you can use for dynamic integers or numbers, but I am not sure how I can change this to display dynamic text.
RobertBorchert
Honored Contributor
In your dashboard there is a pop up when you select an item on the dashboard map
Or you can add  a List or Details element
Set up the list or details to show your string attribute.  then in the actions for the Map set it to filter the List or Details element.
MichelleShaffer
thank you! This helped a lot!
