ArcGIS Dashboard-Arcade Expressions (Math)
4859
11
05-09-2023 08:30 AM
MarlaJohnson
Can you use data expressions in ArcGIS Dashboards to perform math with a pervious record?  The data is stored in ArcGIS Server and pulled into ArcGIS Online .
Tags (1)
jcarlson
Can you give some examples? It's hard to know how the expression is failing without knowing what it's actually doing.
- Josh Carlson
Kendall County GIS
jcarlson
Yes! Provided you can identify what "previous" means with some record sorting, etc., you can easily write an expression that uses the previous record's value to calculate something else.
- Josh Carlson
Kendall County GIS
MarlaJohnson
I am trying to subtract the current day number (chemical reading) from the previous day. It is usually the record right before if sorted by date The issue is Arcade expression is not calling the data, which makes me think I am doing it wrong.
jcarlson
Can you share the expression?
- Josh Carlson
Kendall County GIS
MarlaJohnson
I have tried a lot of different things. I do have an empty field I can place the results in. This is for a serial chart.
var portal = Portal('https://www.arcgis.com');
var fs = FeatureSetByPortalItem(portal, 'fcb8c011c9f44ad09e735683da808b41');
var currentIndex = feature['OBJECTID'];
var previousIndex = currentIndex - 1;
if (previousIndex > 0) {
var previousRecord = FeatureByIndex(fs, previousIndex);
var previousValue = previousRecord['INSPAnswerNumber'];
var currentValue = feature['INSPAnswerNumber'];
if (!IsEmpty(currentValue) && !IsEmpty(previousValue)) {
return currentValue - previousValue;
return null;
jcarlson
I'm not sure how you ended up with that expression. The FeatureSetByPortalItem function requires you to specify the layer index, and it won't get past the second line as its written. Even if it did, it needs to return a FeatureSet object.
The way Data Expressions work is a bit different from other Arcade profiles. If you haven't yet, take a look at some of the expressions here:
https://github.com/Esri/arcade-expressions/tree/master/dashboard_data
In particular, note how you need to first define a dictionary with the fields defined and an empty array for the features. Then you need to loop through every feature in your FeatureSet to push attributes to that dictionary. It will look very different from what you have posted.
    portal,
    'fcb8c011c9f44ad09e735683da808b41',
    0,
    ['some_field'],
    false
var out_dict = {
    fields: [
        {name: 'some_field', type: 'esriFieldTypeInteger'},
        {name: 'difference_from_last', type: 'esriFieldTypeInteger'}],
    geometryType: '',
    features: []
var prev_val = 0
for (var f in fs) {
    Push(
        out_dict['features'],
            attributes: {
                some_field: f['some_field'],
                difference_from_last: f['some_field'] - prev_val
    prev_val = f['some_field']
return FeatureSet(Text(out_dict))
- Josh Carlson
Kendall County GIS
MarlaJohnson
I updated it to this but not exactly getting the correct data back. One day someone puts in data, a number. The second day someone puts in data, a number. I need it to look at the second day and subtract it from the first day. It is easy in python.
var fs = FeatureSetByPortalItem(portal, 'fcb8c011c9f44ad09e735683da808b41', 0, ['INSPAnswerNumber'], false);
var out_dict = {
fields: [
{ name: 'INSPAnswerNumber', type: 'esriFieldTypeInteger' },
{ name: 'difference_from_last', type: 'esriFieldTypeInteger' }
geometryType: '',
features: []
var prev_val = 0;
for (var feature in fs) {
var current_val = feature['INSPAnswerNumber'];
Push(out_dict['features'], {
attributes: {
INSPAnswerNumber: current_val,
difference_from_last: current_val - prev_val
prev_val = current_val;
return FeatureSet(Text(out_dict));
jcarlson
Well, that can depend on the data itself. Is the field actually an integer, or does it need to be converted?
Are you records already in the appropriate order? You may need to use Sort if not.
What are you getting back, if anything?
- Josh Carlson
Kendall County GIS
MarlaJohnson
The data is an interger I am getting back weird numbers that make no sense.
jcarlson
- Josh Carlson
Kendall County GIS
