Arcade for Data Expression
3507
06-05-2024 02:12 AM
MariusVerdes
Hello,
I’m working on a new dashboard based on data from an existing survey, but I’m new to Data Expressions, and I’ve hit a roadblock.
I want to create 4 different elements.
  1. Indicators:
    • I want to create two indicators:
      • One for the count of surveys with only “Yes” answers.
      • Another for the count of surveys with no answers.
    • Null values should not impact the counting.
  2. Bar Chart:
    • Additionally, I’d like to create a bar chart showing the total number of “NO” answers per chapter and per question.
I’ve attached the layer information with all the columns.
Thanks in advance for any suggestions!
Tags (1)
MariusVerdes
I was able to create something for the indicator but it returns JSON instead of the number as the final result
"// Define the FeatureSet including all necessary fields
var fs = FeatureSetByPortalItem(
Portal('URL of the enterprise'),
'id of e feature layer',
0,
["Count_No", 'Q1_1', 'Q1_2', 'Q1_3', 'Q1_4'],
false
// Calculate the number of No answers
var noCount = 0;
for (var i = 0; i < 86; i++) {
var columnName = "column_" + i; // Adjust this according to your column naming convention
noCount += Count(Filter(fs, columnName + " = 'No'"));
var ratioDict = {
'fields': [
{'name':'No_Count', 'type':'esriFieldTypeInteger'}
'geometryType': '',
'features': [{
'attributes': {
'No_Count': noCount
// Transform the dictionary into a FeatureSet and return it
return FeatureSet(Integer(ratioDict));"
KenBuja
MVP Esteemed Contributor
Use this as the final line
return FeatureSet(ratioDict);
MariusVerdes
Hi @KenBuja
Thanks for the tip, it solved the error from the Arcade editor inside the Dashboard, but after I click "Done" it says that it is unable to execute the script (see the below screenshots). Any idea why this happens?
KenBuja
This code (leaving off the calculation to No Count) give me a FeatureSet. What does it do in your dashboard?
var noCount = 0
var ratioDict = {
  'fields': [
  'geometryType': '',
  'features': [{
    'attributes': {
      'No_Count': noCount
MariusVerdes
Hi @KenBuja ,
No, it gives the following error "Execution error - Line: 15, 7: Invalid parameter"
But, I tried a workaround with an attribute rule and it gives me what I need. The code for the attribute rule is:
var countNo = 0;
if ($feature.Q1_1 == 'No') {
countNo += 1;
if ($feature.Q1_2 == 'No') {
countNo += 1;
if ($feature.Q1_3 == 'No') {
countNo += 1;
if ($feature.Q1_4 == 'No') {
countNo += 1;
if ($feature.Q2_1 == 'No') {
countNo += 1;
if ($feature.Q2_2 == 'No') {
countNo += 1;
if ($feature.Q3_1 == 'No') {
countNo += 1;
if ($feature.Q3_2 == 'No') {
countNo += 1;
if ($feature.Q3_3 == 'No') {
countNo += 1;
if ($feature.Q3_4 == 'No') {
countNo += 1;
if ($feature.Q3_5 == 'No') {
countNo += 1;
if ($feature.Q3_6 == 'No') {
countNo += 1;
if ($feature.Q3_7 == 'No') {
countNo += 1;
if ($feature.Q3_8 == 'No') {
countNo += 1;
if ($feature.Q3_9 == 'No') {
countNo += 1;
if ($feature.Q3_10 == 'No') {
countNo += 1;
if ($feature.Q3_11 == 'No') {
countNo += 1;
if ($feature.Q4_1 == 'No') {
countNo += 1;
if ($feature.Q4_2 == 'No') {
countNo += 1;
if ($feature.Q4_3 == 'No') {
countNo += 1;
if ($feature.Q4_4 == 'No') {
countNo += 1;
if ($feature.Q4_5 == 'No') {
countNo += 1;
if ($feature.Q4_6 == 'No') {
countNo += 1;
if ($feature.Q5_1 == 'No') {
countNo += 1;
if ($feature.Q5_2 == 'No') {
countNo += 1;
if ($feature.Q5_3 == 'No') {
countNo += 1;
if ($feature.Q5_4 == 'No') {
countNo += 1;
if ($feature.Q5_5 == 'No') {
countNo += 1;
if ($feature.Q5_6 == 'No') {
countNo += 1;
if ($feature.Q5_7 == 'No') {
countNo += 1;
if ($feature.Q6_1 == 'No') {
countNo += 1;
if ($feature.Q6_2 == 'No') {
countNo += 1;
if ($feature.Q6_3 == 'No') {
countNo += 1;
if ($feature.Q6_4 == 'No') {
countNo += 1;
if ($feature.Q6_5a == 'No') {
countNo += 1;
if ($feature.Q6_5b == 'No') {
countNo += 1;
if ($feature.Q6_5c == 'No') {
countNo += 1;
if ($feature.Q6_5d == 'No') {
countNo += 1;
if ($feature.Q6_5e == 'No') {
countNo += 1;
if ($feature.Q6_5f == 'No') {
countNo += 1;
if ($feature.Q6_5g == 'No') {
countNo += 1;
if ($feature.Q6_5h == 'No') {
countNo += 1;
if ($feature.Q6_5i == 'No') {
countNo += 1;
if ($feature.Q6_6 == 'No') {
countNo += 1;
if ($feature.Q6_7a == 'No') {
countNo += 1;
if ($feature.Q6_7b == 'No') {
countNo += 1;
if ($feature.Q6_8 == 'No') {
countNo += 1;
if ($feature.Q6_9 == 'No') {
countNo += 1;
if ($feature.Q6_10 == 'No') {
countNo += 1;
if ($feature.Q6_11 == 'No') {
countNo += 1;
if ($feature.Q6_12 == 'No') {
countNo += 1;
if ($feature.Q6_13 == 'No') {
countNo += 1;
if ($feature.Q6_14 == 'No') {
countNo += 1;
if ($feature.Q6_15 == 'No') {
countNo += 1;
if ($feature.Q7_1 == 'No') {
countNo += 1;
if ($feature.Q7_2 == 'No') {
countNo += 1;
if ($feature.Q7_3 == 'No') {
countNo += 1;
if ($feature.Q7_4 == 'No') {
countNo += 1;
if ($feature.Q7_5 == 'No') {
countNo += 1;
if ($feature.Q7_6 == 'No') {
countNo += 1;
if ($feature.Q7_7 == 'No') {
countNo += 1;
if ($feature.Q7_8 == 'No') {
countNo += 1;
if ($feature.Q7_9 == 'No') {
countNo += 1;
if ($feature.Q7_10 == 'No') {
countNo += 1;
if ($feature.Q7_11 == 'No') {
countNo += 1;
if ($feature.Q7_12 == 'No') {
countNo += 1;
if ($feature.Q7_13 == 'No') {
countNo += 1;
if ($feature.Q7_14 == 'No') {
countNo += 1;
if ($feature.Q7_15 == 'No') {
countNo += 1;
if ($feature.Q7_16 == 'No') {
countNo += 1;
if ($feature.Q7_17 == 'No') {
countNo += 1;
if ($feature.Q7_18 == 'No') {
countNo += 1;
if ($feature.Q7_19 == 'No') {
countNo += 1;
if ($feature.Q7_20 == 'No') {
countNo += 1;
if ($feature.Q7_21 == 'No') {
countNo += 1;
if ($feature.Q7_22 == 'No') {
countNo += 1;
if ($feature.Q8_1 == 'No') {
countNo += 1;
if ($feature.Q8_2 == 'No') {
countNo += 1;
if ($feature.Q8_3 == 'No') {
countNo += 1;
if ($feature.Q8_4 == 'No') {
countNo += 1;
if ($feature.Q8_5 == 'No') {
countNo += 1;
if ($feature.Q8_6 == 'No') {
countNo += 1;
if ($feature.Q8_7 == 'No') {
countNo += 1;
if ($feature.Q8_8 == 'No') {
countNo += 1;
if ($feature.Q9_1 == 'No') {
countNo += 1;
if ($feature.Q9_2 == 'No') {
countNo += 1;
if ($feature.Q9_3 == 'No') {
countNo += 1;
if ($feature.Q10_1 == 'No') {
countNo += 1;
if ($feature.Q10_2 == 'No') {
countNo += 1;
if ($feature.Q10_3 == 'No') {
countNo += 1;
if ($feature.Q10_4 == 'No') {
countNo += 1;
if ($feature.Q10_5 == 'No') {
countNo += 1;
return countNo;"
