Arcade Data Expression- Dictionary from multiple tables
9968
20
12-23-2021 08:04 AM
TSmith
I am interested in feeding a dashboard with values from multiple tables. I have the following code below:
var portal = Portal('yourportalurlhere');
var valvefs = FeatureSetByPortalItem(portal,'id',index,["*"],false);
for (var v in valvefs){
   var relatedrecords = OrderBy(FeatureSetByRelationshipName(v, 'System_Valve_Inspection', ["*"],false),'insdate DES');
   var recentrecord = First(relatedrecords)
   for (var r in recentrecord){
       var feat = {
           attributes: {
               assetid: r["valveid"],
               insdate: r["insdate"],
               diameter: v["diameter"],
               turns: r["turns"],
               fintorque: r["fintorque"],
   } Push(features,feat);
var joinedDict = {
  fields: [
    { name: "assetid", type: "esriFieldTypeString" },
    { name: "insdate", type: "esriFieldTypeDate" },
    { name: "fintorque", type: "esriFieldTypeDouble" },
    { name: "turns", type: "esriFieldTypeDouble" },
    { name: "diameter", type: "esriFieldTypeDouble" },
geometryType: '',
features: features
I'm wanting to grab two values from the parent table (diameter and assetID) and other values from the most recent inspection record. I'm not sure why the code isn't working, but the error I keep getting is
Execution Error:Runtime Error: Cannot call member property on object of this type.
Any help is appreciated! I got something similar working, however all of the values come from the same table.
PeterBrad3
I have a similar expression that joins together an asset and its most recent inspection record. The feature set populates with all the data as expected but I would like the feature set to display the domain description instead of the domain code. For example, currently in the output feature set the "Site Type" field for a record is "ts" where I would like it to have its domain description "Transfer Station". Any advice is appreciated.
