Arcade Code for joining to hosted table for using it on Dashboard
8254
05-12-2022 10:22 AM
anonymous55
Hello All,
I am looking for a arcade code which I can bring one or two fields from another table and join it with another hosted table then use it on dashboard as Table or list.
I don't know if this is possible using Arcade? I can use join function in arcgis online but how can I keep that up to date
2 Solutions
jcarlson
It sounds like you could use a Data Expression! There is an example expression for just such a scenario right here: https://github.com/Esri/arcade-expressions/blob/master/dashboard_data/JoinLayerFieldsToTable.md
- Josh Carlson
Kendall County GIS
Soobin-Choi
Hi there,
Another method would be to use a field join to join the tables/layers from Map Viewer, then publishing the joined result as a feature layer view.
Credit is not required and the data will stay up to date. Depending on the size of your dataset, using data expressions to "join" tables may cause a performance lag when loading dashboard elements. This view option might be a more scalable alternative.
jcarlson
- Josh Carlson
Kendall County GIS
StephenKaranja
Soobin-Choi
Hi there,
