Adjust height between bars in series
1293
02-08-2020 06:15 AM
MikeOnzay
Is there any way to adjust these bars to be close in height? Without looking at the numbers it looks much greater than 1 unit.
Tags (1)
VivekMalleshappa
Esri Alum
Hi Mike,
The Value axis minimum value configuration is set to 'Automatic' by default (screenshot below). If you set it to a lower value, say zero, you can see that the height difference in bars decreases.
-Vivek.
VivekMalleshappa
Esri Alum
Hi Mike,
-Vivek.
