Add/delete attachments using ArcGIS Dashboard
321
07-01-2026 04:57 PM
mp_torimurrant
I'm creating a dashboard to allow staff to edit features using the Dashboard application (ExB wasn't suitable for the use case). I've configured a Form for the layer using the Map Viewer, including the ability to add/delete/m odify attachments (see image 1).
When the feature is selected, the Table widget allows the user to edit the pre-configured form. However, the attachments field doesn't appear (see image 2). Is this a known limitation or am I missing something?
Thank you.
HollyTorpey_LSA
I'm not sure there's a way to edit attachments in Dashboards, but you might want to consider the Manager Instant App. If I recall correctly, you can edit attachments there and it has kind of a dashboard-like interface.
- Holly
