Serial Chart - Ability To Invert Y Axis - ArcGIS Dashboards
7358
11
11-09-2020 04:44 PM
JonathanMcDougall
The ability to invert the Y axis of a serial chart to allow, for example, river level sensor data to be shown as you'd expect. High water (low distance to the sensor)  would be represented at the top of the graph, not the bottom.(see attached image) #dashboard-beta
11 Comments
cbp-geus
So, five years since this was suggested, and still not implemented. It should be straightforward to simply add a toggle to invert the axis. This is a common requirement when working with scientific data. Typically, we use positive values when modeling geological surfaces below ground level, defined as 'meters below surface', but this doesn't work well when displaying the data on a graph, where you’d expect either an inverted axis or negative values.
