Ops Dashboard Indicator widget with multiple conditions
605
06-16-2020 11:39 PM
Status: Open
BenJarlett
New Contributor II
It would be great if the Indicator widgets could be configured to use multiple conditions (more than 2) ie
  • Above, below and equal to the reference value/attribute or
  • by explicitly setting conditions for individual values (if value = high make red, if value = medium make orange if value = medium-low make yellow if value = low make green or
  • ranges of values of the indicator or reference attribute for example if value is between 0-5 make green, if value is 5-10 make orange, if 10-100 make red.
Also being able to apply some smarts (arcade maybe) to the indicator values and or reference values would really help.
cheer
Ben
1 Comment
VivekMalleshappa
Hi @BenJarlett
You can now create indicators with conditional formatting for multiple conditions using Arcade scripts in the Beta release of ArcGIS Dashboards. Check out this blog by my colleague @DavidNyenhuis1 : https://www.esri.com/arcgis-blog/products/ops-dashboard/real-time/getting-started-with-arcade-in-arc...
-Vivek.
