Lock Dashboard Map Element - No Zoom, No Pan
6311
8
12-09-2019 05:17 AM
AdamRepsher
Scenario 1:
You have a simple statewide, county based, choropleth map‌.  You need to display it at its full extent and allow users to select a county.  That simple action then drives a number of other elements, displaying many different metrics on that county to your users.  A subtitle for the map explains: "Select a county to see statistics."
Simple, right?  Sorry - No.
If the user mistakenly pans or zooms, they need to then know how to get their map back to where it started.  you have to add another button in the Map element and then change your subtitle: "Select a county to see statistics.  If you happen to move or zoom the map and want to return to where you were, find the Home button in the map frame and click or tap it."
Scenario 2:
The map contains many complex, overlapping polygons that require a lot of time to load.  Once loaded, they are cached.  Movement in this scenario is catastrophic. If the map pans or zooms, the polygons must load again.   In its default extent, the user is able to see the results of removing various polygons at a statewide level, and no map movement is required.  I need this for a working group that is studying various combinations of RF footprints in a statewide, multiband, P25 land mobile radio system - to create coverage classes.  I am using a Category Selector to choose the footprints.
Locking the map frame in the Operations Dashboard for ArcGIS‌ to panning and zooming - if that is the needed functionality - is essential.  If a dashboard only needs a map with selectable counties at a statewide extent, why let it inspect the backyard of your neighbor - or look at the entire globe?
In both of the scenarios above, I need the user to push a button or select a county.   Any other operation is not wanted.  Any other operation creates confusion and necessitates extraneous explanations "just in case" a user does "something else."
I believe that this functionality was available in the original Dashboard, and I found myself searching for it in this edition - with no luck.
8 Comments
patrickb
AdamRepsher
Thank you @patrickb
This is one that I still could use many times over - and now in the new Dashboards....
--Adam
DanielMyers
This would be really useful for publicly embedded app/maps as well. Scrolling on a site and then meeting a scrolling map can be a pain for some users.
RandyMcGregor3
This would be extremely helpful. In fact, it seems like a bug. Why have the option to disable 'Zoom' when users can easily zoom in and out of the map when that is set?
I have an overview map that I would like to remain at the same scale. One accidental click and the user is going to have to figure out how to get the map back to its full extent. Not difficult, but something I'd rather not have in the mix.
Thank you,
Randy McGregor
ADMINCITYCARE
Hi @patrickb , do we have any update on this status? Regards
wmancini
We need this desperately. There are many use cases where locking in the map extent on the dashboard is very useful.
ERASERacism
Yes, we 100%, urgently, NEED a way to disable the zooming in and out that happens when a user is simply scrolling over a map. I have a dashboard of tracts in NY state and its constantly zooming out to the world scale, making it extremely frustrating for the user to get back to the map. Can @ESRI1  please prioritize this?
DRicotta
Also looking for this, surprised it's not an option yet.
