Improve Output Window in Dashboard Data Expression Area
655
12-02-2025 07:21 AM
Status: Open
Jennifer_Parmeley
I'm working with a data expression in a Dashboard. I have arcade combining things and sorting them out - new variables, fields, lots of stuff. All of this has been easy enough to accomplish; the MOST frustrating part is that I cannot see the headers of my columns and my scoll bar on the bottom of the results window at the same time.
When I click run to test see my result table, I cannot see my scroll bar on the bottom on the results.
result window with headers
If I scroll to the bottom of the table I cannot see the headers. The results window cannot be adjusted/drag up - like is common in most web tables.
result window scrolled to the bottom to show the left/right scroll bar - missing headers
Can the result window be improved? Make the scroll bars always visible.
2 Comments
RPGIS
by MVP Regular Contributor
Hi @Jennifer_Parmeley,
To Clarify, just so others can get a better understanding of what you mean, do you mean to add the ability to freeze fields so users can still see the fields as they scroll.
The other slight workaround is to zoom out of the webpage but that will result in the text shrinking throughout.
I think the ability to freeze fields/column headers would be a more straightforward improvement.
Jennifer_Parmeley
Freezing fields would be fine - as long as it would apply to the header.
Agreed that zoom out in the browser is a slight workaround.
